Old April 2nd, 2012, 01:59 PM   #21 (permalink)
RogerC's Avatar
tasty carve. that's on my list of things to do on a future build.
RogerC is online now
Old April 2nd, 2012, 02:00 PM   #22 (permalink)
pulaifaz's Avatar
Originally Posted by emoney View Post
Nice way to shave 3lbs off that thing! Have you chosen which of the finishes you were
debating about? Either will be pretty sweet.
thanks emoney, I love how light it feels - regarding the finish, at the moment I think am going for an amber on the top and darker body
pulaifaz is online now
Old April 2nd, 2012, 02:03 PM   #23 (permalink)
pulaifaz's Avatar
thanks RogerC - it's a lot of work, but I think it's worth it
Old April 2nd, 2012, 03:09 PM   #24 (permalink)
Muzikp's Avatar
Great build, going to look nice. Would you mind sharing how you roughed in the contours for the carve?
_______________________________________________
James
Muzikp is offline
Old April 2nd, 2012, 03:19 PM   #25 (permalink)
pulaifaz's Avatar
thanks Muzikp
sure, I didn't take any photos, but I used my Les Paul carve templates that were borrowed from another builder called ex-nihilo in mylespaul.com - follow this thread it has a link for the download
Old April 4th, 2012, 10:44 PM   #26 (permalink)
pulaifaz's Avatar
Starting work on the 1 piece maple neck
I will use a two-way truss rod with the adjustment at the heel
routing the truss rod channel
channel is done
fitting the truss road adjustment nut
finished
Old April 4th, 2012, 10:46 PM   #27 (permalink)
pulaifaz's Avatar
Starting to look at possible finish dyes
amber
this one is called merlot
Old April 5th, 2012, 11:08 PM   #28 (permalink)
pulaifaz's Avatar
Continued shaping the neck
it will be routed next
Old April 7th, 2012, 06:44 PM   #29 (permalink)
pulaifaz's Avatar
while routing the neck the template slipped and the neck was damaged beyond repair, I decided not to use any screws to hold the template
so off to start another neck from scratch .....
Old April 7th, 2012, 06:51 PM   #30 (permalink)
pulaifaz's Avatar
here's the new neck blank
for this one I cut closer to the lines, and the straight sections were routed and the rest were sanded with the ROSS
next I glued the skunk stripe, using some oak
Old April 7th, 2012, 07:05 PM   #31 (permalink)
Love the guitar. Your giving me inspiration for my next build.
With the carve did you have templates for each step? If you I'd how did you design them? Just freehand?
Cheers
Guitar novice is offline
Old April 7th, 2012, 11:27 PM   #32 (permalink)
pulaifaz's Avatar
thanks Guitar novice
one template per step
Old April 7th, 2012, 11:42 PM   #33 (permalink)
BR06623's Avatar
I like your inspiration guitars also. The carve you are doing looks real nice, can't wait to see the finished product. Good luck!
BR06623 is offline
Old April 7th, 2012, 11:43 PM   #34 (permalink)
Great woodworking skills Paulifaz. I like the anber MHO.
Tonetele is offline
Old April 8th, 2012, 09:44 PM   #35 (permalink)
pulaifaz's Avatar
thanks BRO
Old April 8th, 2012, 09:46 PM   #36 (permalink)
pulaifaz's Avatar
you're too kind Tonetele - but I feel I am more like a hack who has learned a lot from all the kind people in this forum who share their jigs and techniques
Old April 8th, 2012, 09:52 PM   #37 (permalink)
pulaifaz's Avatar
I carved the back of the neck using Bill Scheltema's neck router jig and some sanding
I love that jig
Old April 8th, 2012, 09:53 PM   #38 (permalink)
emoney's Avatar
Man, I think I like both those colors. It's really shaping up nicely!
emoney is offline
Old April 8th, 2012, 10:02 PM   #39 (permalink)
pulaifaz's Avatar
thanks emoney - I can't decide about the color, but there's still a lot of the wood work to be done before I get there
Old April 8th, 2012, 10:19 PM   #40 (permalink)
Nice work with the Scheltema jig! You stop the carve further
than the headstock than I do, but that is probably a good idea.
I really like the control and consistency you get with that jig.
flatfive is offline
