Old March 17th, 2012, 03:42 AM   #21 (permalink)
kwerk's Avatar
Looking great, Mike. Things are getting exciting, huh?
Phil
kwerk is offline
Old March 17th, 2012, 02:15 PM   #22 (permalink)
junk mutt's Avatar
Your's was my fave from last year Mike so I'm expecting great things from you this year Nice ash by the way
junk mutt is offline
Old March 17th, 2012, 02:29 PM   #23 (permalink)
adirondak5's Avatar
Beautiful grain in that ash Mike .
Herb
adirondak5 is offline
Old March 17th, 2012, 03:01 PM   #24 (permalink)
hockeygoon's Avatar
Wow, I really love how three-dimensional that grain looks w/o a finish. It should look great after you work your magic on it.
"Where the he11's my pick?"
hockeygoon is offline
Old March 17th, 2012, 07:07 PM   #25 (permalink)
formerly "Big" Mike Simpson
Mike Simpson's Avatar
Today I cut the body out with my bandsaw, ran it through the planer, used the ross to smooth the saw cut so the router won't be cutting too much or have any saw edges to catch on.
ID:	119386   Click image for larger version
ID:	119387   Click image for larger version
Mike Simpson is offline
Old March 17th, 2012, 07:13 PM   #26 (permalink)
Next I routed the outside, used a forstner bit to remove some wood from the routes and routed the neck pocket, pickups and the control cavity.
ID:	119389   Click image for larger version
ID:	119390   Click image for larger version
Old March 17th, 2012, 07:16 PM   #27 (permalink)
I still need to drill the jack socket and bridge holes but I gotta get ready for a gig tonight at The Handlebar Pub and Grill in Apache Junction, AZ. I will try to get more done tomorrow. I am still deciding netween a string ferrule bar and regular ferrules.
Also you can see that I am using a P-90 route so I can choose between P-90, Mini Humbucker or Tele neck pickup depending on the pickguard.
Old March 17th, 2012, 09:33 PM   #28 (permalink)
nosmo's Avatar
That's pretty cool with the interchangable pickups, but if I did that why would I need 14 or so guitars?
Telecaster - The AK-47 of the guitar world. Some may think its ugly...but it works!
nosmo is offline
Old March 17th, 2012, 11:10 PM   #29 (permalink)
DesmoDog's Avatar
Remember to roundover the edge before you drill the jack socket out or the bearing on the roundover bit will fall into the socket hole, and that's never good.
-Craig
http://www.teamyikes.com/
DesmoDog is offline
Old March 17th, 2012, 11:18 PM   #30 (permalink)
Hi mike. What do you think of the sander. Thinking of getting one.
Love the grain on is one
Cheers
Guitar novice is offline
Old March 18th, 2012, 12:50 PM   #31 (permalink)
Thanks... yeah I have done that before...
Old March 18th, 2012, 12:55 PM   #32 (permalink)
Cheers
The sander is pretty handy for a few operations. I usually keep a pretty rough belt on it for roughing things out quickly. The oscillating movement of the helps make smooth sanding on the edges. Mine is an older machine that I bought used for $40.
Old March 21st, 2012, 02:19 AM   #33 (permalink)
Tonight I drilled the wiring holes, the string through holes and the bridge screw holes. I took pics of drilling the wiring holes but they came out blurry. I guess I fail at one handed camera.
Old March 21st, 2012, 02:24 AM   #34 (permalink)
I bought one of those Stwemac fret slotting blades for my little table saw and a 25.5"/25"
I spent some time making a slotting sled so I can slot fretboards on the table saw.
Here is a pic of it before I finished gluing and screwing it together. I made it wider and taller than needed for seperate fretboards so I could slot one piece neck blanks with this as well.
Old March 21st, 2012, 08:37 AM   #35 (permalink)
RogerC's Avatar
I got the same setup for my RAS for Christmas this past year. LOVE it! Fret boards take no time at all now. The nice thing about the RAS vs the table saw is that I can radius the fretboard before I slot it.
RogerC is online now
Old March 26th, 2012, 01:15 AM   #36 (permalink)
I finished up my slotting sled and put some screws through the maple into the alder since I cut through the mcf with the regular saw blade to clearance for the slotting blade.
ID:	120936   Click image for larger version
Old March 26th, 2012, 01:16 AM   #37 (permalink)
I screwed up on the indian rosewood neck and had to start over with a cocobolo neck.
ID:	120938   Click image for larger version
Old March 26th, 2012, 01:18 AM   #38 (permalink)
Next I routed for the truss rod.
Name:	2012-TDPRI-truss rod route.jpg
Old March 26th, 2012, 01:21 AM   #39 (permalink)
I cut out the neck on the bandsaw... it is really hard to see the lines on dark wood.
If you were wondering what happened to the indianrosewood neck... I am Simpson... lord of the idiots... I drew the outline on the back without flipping the pattern over and I cut it out left handed... D'oh !
Old March 26th, 2012, 01:24 AM   #40 (permalink)
Instead of routing I sanded the cocobolo neck to the line with the Ross... since I also screwed up the left handed indian rosewood neck even further when my routing pattern slipped...
