Old March 17th, 2012, 01:30 AM   #21 (permalink)
Muzikp's Avatar
Will you have to squeegee it down after each night of gigging? Might be the first instrument where cleaning it with windex IS the recommended method.
Muzikp is offline
Old March 17th, 2012, 01:49 AM   #22 (permalink)
Barncaster's Avatar
Originally Posted by motor_city_tele View Post
here is what I will be building my 2012 challenge out of.
The long piece of rough sawn lumber is called Guyana Rosewood or Wamara. It is sap wood so it is light in color. I will be making the neck and body supports out of it. It is a very dense wood so the shaping and machining may take a toll on my cutting tools. The rest of the material are sheets of glass. The plan is to build a sunburst esquire.
tootles - jb
jb,
I guess there will be no amp or stage bashing with that rig. You know what they say about people who play glass guitars.....
Barncaster
Barncaster is offline
Old March 17th, 2012, 02:50 PM   #23 (permalink)
Be carefull with that glass, before you know.....
it will break
vintage65 is offline
Old March 18th, 2012, 08:36 PM   #24 (permalink)
motor_city_tele's Avatar
week 1 update 3-18-2012
I found my huge roll of butcher block paper and made a couple of tele body tracings. I needed to know if my hunk of rosewood is going to be enough wood to make all of the wooden parts. I think I have enough - barely. The sketch on the right is a quick pattern that I will use to cut the glass pieces.
That's about I could muster this week.
You're gonna need a bigger boat!
motor_city_tele is offline
Old March 18th, 2012, 09:36 PM   #25 (permalink)
mkhhunt's Avatar
Cool a tiffanycaster! Or is it a cathedralcaster? Will it have internal lighting? That would be cool!
mkhhunt is offline
Old March 18th, 2012, 09:56 PM   #26 (permalink)
They shouldn't play the Rolling Stones??
ChaosRocker is offline
Old March 19th, 2012, 03:54 PM   #27 (permalink)
I'm thinkin' it'll have to light up to have any merit as a lampCaster. The question is do I tear apart one of those Harbour Freight LED flashlites or do I use 6.3 volt incandescent bayonet mounts that I have for my amp builds. and of course, there is the power source to deal with. a 9 volt battery would probably do the job but where does it go. then there is the switch factor.
Old March 19th, 2012, 04:13 PM   #28 (permalink)
jpbturbo's Avatar
tootles - jb
-Josh
Project Designer Emeritus - IGPA
"The Rebel Bass"
Books by Ron Kirn
jpbturbo is offline
Old March 19th, 2012, 04:32 PM   #29 (permalink)
Scooby Snax's Avatar
This is going to be a good one... are you going to use foil or lead cane?
Scooby Snax is offline
Old March 19th, 2012, 04:41 PM   #30 (permalink)
Matt Haskins's Avatar
Very cool. Can't wait to see this take shape.
Other Guy, "But really, how many Telecasters can you have?"
Me, "Ummm.... ya, I'm really the wrong guy to ask about that."
Matt Haskins is offline
Old March 19th, 2012, 04:47 PM   #31 (permalink)
LightninMike's Avatar
For the switch, just tie it into the jack - use a stereo jack so one part is only the negative connector on the light circuit....
LightninMike is offline
Old March 19th, 2012, 08:55 PM   #32 (permalink)
nosmo's Avatar
When you build a guitar as nice as the one you built last year, it makes it kind of tough to step it up a notch dosen't it? I think you're on the right track though. This should be awesome.
Telecaster - The AK-47 of the guitar world. Some may think its ugly...but it works!
nosmo is offline
Old March 20th, 2012, 07:44 AM   #33 (permalink)
It'll be foil.
tootles - jb
Old March 24th, 2012, 11:00 PM   #34 (permalink)
glass cutting and shaping
I started cutting glass this evening. If you haven't stumbled upon Vicky Payne on PBS and watched her stained glass show, this is how it's done.
The pattern is pinned down and the pieces are assembled on top of it.
Some card stock is slipped under the pattern.
Some transfer paper (carbon paper) is slipped between the card stock and the pattern.
A good sharp strong pencil will transfer the piece outline onto the card stock.
The template for the next piece of glass is ready. I mark the top with an X
The template is cut out and the outline is traced onto a piece of glass. Since this piece is black, a paint pen is needed to see the lines.
The paper is removed and the glass is ready to cut.
I use an oil cutter. I push the cutter down with pressure that scores the glass. It snaps off pretty easy with a pair of glass cutting pliers.
The piece is shaped with a glass grinder until it fits accurately against the piece next to it.
When the piece is the correct shape, copper foil is applied along the edges.
The edges are burnished with a piece of dowel.
The piece is positioned and flux is applied.
The soldering gun is ready to go. A damp sponge is used to keep the tip clean.
Tack the pieces together.
Repeat this for every piece of the puzzle.
Tomorrow I'll cut and grind the red, amber, and white glass.
btw, earlier I got started on my 2014 build challenge. - 2 years from now
Remember that cherry tree I cut down? Here is the trunk staring at some serious bandsaw.
It was a hell-a-va lot easier getting it into the trunk the second time.
I will stack the pieces in a corner someplace for the next year or so to dry.
Old March 24th, 2012, 11:02 PM   #35 (permalink)
kwerk's Avatar
Incredible. This is going to be out of this world.
Phil
kwerk is offline
Old March 24th, 2012, 11:09 PM   #36 (permalink)
nosmo's Avatar
Of all the builds, I think this is the one, well in the top two, or three...dang it, I really want to see this one!
If, for any reason, you're not happy with it when you're done I'll send you my address.
nosmo is offline
Old March 24th, 2012, 11:12 PM   #37 (permalink)
Wicked work, I think you'll have to change your handle to "Tiffany" as in Wm. not the Redhead...
Old March 24th, 2012, 11:21 PM   #38 (permalink)
emoney's Avatar
This gonna be, quite possibly, the coolest guitar I've ever seen. Exciting just watching
it develop.
Oh...and I've got this feeling your trunk looks a lot like mine, lol.
emoney is offline
Old March 24th, 2012, 11:52 PM   #39 (permalink)
I find it hard to believe you are only building one or are there others being built in the background that you are not telling us about.
onenotetom is offline
Old March 25th, 2012, 12:37 AM   #40 (permalink)
RogerC's Avatar
I said this on another thread, and I'll say it again here--
I just KNEW that my cement guitar would be the most inventive use of materials this year... WRONG
This is going to look spectacular!
RogerC is online now
