| 2012 TDPRI Tele Build Challenge 2012 Build Challenge Forum -- check out all the build threads for this year's Challenge. |
#261 (permalink) |
I like the aluminum spacer; it takes what was a mistake and turns it into a definite asset. Design-wise, it really ties in the truss rod plug liner from the other side of the headstock. I wouldn't have thought I'd like the aluminum features, but you've pulled everything off in a very classy way.
M Dixon Reading, MA |
#262 (permalink) | |||
Thanks, ya after thinking about it for a while, I just did not like the idea of adding wood as the neck is a single piece of Khaya and I want to keep the grain that's there.
Ya - that spacer is really stiff, way stiffer than the wood I used - so that helps correct the extra flex that the headstock would have had too. Quote:
It will great to finally get this bolted up to the body. |
#263 (permalink) |
Tonight I swapped out the nickle Sperzels in the above pictures with some satin chrome tuners that I had on a different guitar. Then I finished drawing up a pickguard and cut it out to see how it might work with the body.
I did not get any work done on the bridge, I was trying to figure out if I was going to try to go with a 3 or a 6 saddle bridge - and if a 3 saddle bridge, should I go with the thin rod (3/16") or thick rod (3/8) for the saddles? Here's some pictures of the bridges I've done in the past, I can't quite decide... Maybe I'm leaning towards the 3/8" rod... Then, I got one more coat of AOF on the neck. I have another business trip this week, so I don't know if I'll make a lot of progress this week. But I think that's OK - the neck will completely dry in a few days and then the bridge and pickguard should go pretty quickly. |
#264 (permalink) |
Mojo, great solution to the headstock thickness problem -- it
ends up being a nice cosmetic element, too. You mentioned ginger ale -- I've always found it funny that you rarely see it around, but you can always get it on a flight. Why? |
#265 (permalink) |
That pg is going to look great. Couple it with the aluminum, and you have a cool retro/futuristic look.
"The difference is that you're crazy like Nicolai Tesla and I'm more like the guy who sniffs paint and rides his bike down the middle of the road" - Me to Crazydave911 |
#266 (permalink) | ||
#268 (permalink) |
Back home and still pluggin' away. I worked on the bridge.
Made some saddles. I thought I would try some different methods of making these: Here, instead of filing off the bottom, I kept the rod sections as big as possible to keep the mass of the saddle as high as possible. Filed the sides. I did some routing on the sides, but at the end of the day I did most of the shaping with files... Worked pretty well. I think that's the best bridge I've made so far. |
#270 (permalink) |
Thanks. Ya, that Aluminum will shine up pretty well. I don't know yet - I have to see how much time I have. That is sanded to 600gt, I wanted to leave it there until I have everything assembled.
#272 (permalink) |
Thanks - yep that's what I had in mind. I have 2 sets of tuners - Nickel and 'satin silver' so, I'll figure out which look the best in a couple of days when I start assembling things.
#273 (permalink) |
Very nice bridge
#274 (permalink) |
Love the bridge , and the headstock/tuner shim , nice metal work
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
#275 (permalink) |
Thanks Herb and Roger - I'll have to learn how to do nickel plating at some point, but I think Aluminum gets the job done and is super easy to work. I did a few bridges in Steel a couple years ago and it was much much harder.
#276 (permalink) | |
As for the Durhams chipping (same for Bondo) - when I use it I like to lay down some thin CA glue after the water putty or bondo has dried. The water putty and Bondo absorb the glue quite well. This does 2 things - helps harden the filler and make it easier to hold a shape (harder to sand but it won't chip or crack). I use the same CA trick on the sides of my MDF templates - helps prevents any nicks or dings from normal use. Stinks a lot - those fumes are nasty - but it works great. BTW - awesome job on the neck and body. I love the added details of the aluminum - it really "snazzes up" the look. Great job.
Pursue your dreams...and hopefully you have a Tele, tube amp and cold beer to accompany you on your journey! ---------------------------------------------- Twang on...HiggyDude Http://www.higgydude.com |
#279 (permalink) | ||
Thanks - ya I like the look of rosewood strip/plug with a rosewood fretboard... but I think this Aluminum has really grown on me.. used it quite a bit on last year's challenge as well. |
#280 (permalink) |
The Evolution of a Pickguard :)
The tricky thing about making a custom pickguard is the layout of the controls and matching up with the pickup holes as well as the neck...
So what I do is I make a clear one first, that way I can layout everything and be able see where everything is below... I will love to get to the point where I can play it :) |
