| 2012 TDPRI Tele Build Challenge 2012 Build Challenge Forum -- check out all the build threads for this year's Challenge. |
#21 (permalink) |
Last night I had a couple of hours to get some more work done. First I took the body blank out of the clamps, it just might work.
![]() Next it was on to getting the top ready, so I marked out a 1/2" line and headed to the bandsaw ![]() Not the best job here, but I went 1/2" so I'd have enough material to work with. After cutting the next two pieces I noticed the band saw struggling due to my wondering line and the wondering was getting worse. Before I ripped the last piece I ran the piece I was using through the planer to straighten up the guide edge...I should have done that every time. ![]() After cutting them all I had to plane them to get a good side ![]() then used that good side to joint them up ![]() Now we're getting somewhere ![]() I've never clamped up a top before so I wasn't sure what would be best. I laid some wax paper down first then clamped as best I could and went for some weights to keep the center down ![]() After getting back from an evening with friends out of the clamps it came
C. Dilbone *3rd rate hack*
#22 (permalink) |
I think it's taking me as long to upload/edit pics and post all this as it is to actually do the work. Between posting/reading posts/and building I barely have time to eat or sleep...
Looks like I've got plenty of thickness here to bring the total down to 1.75" ![]() ![]() Before I can plane them I have to trim them down to 13" to fit through the planer ![]() ![]() As I was planing along I end up uncovering these...weepy sap pockets...not good. I considered cut that piece out of the body and gluing another one in its place, but I still had quite a bit to remove and it cleaned up fairly well ![]() ![]() A little better here... this will be the back...may have to CA it, not sure what to do to seal it ![]() this one will be under the cap, so it's all good ![]() Top cleaned up nicely too ![]() After all that planing I made a few more shavings ![]() ![]() time to get out the templates ![]() and the cavity template...I put holes in the perimeter so I could line it up easier over the outline ![]() Off to the band saw ![]() and the top ![]() I'll have to post the rest of today's progress tomorrow...gotta hit the hay
#23 (permalink) |
Looking good Chris , I gotta pick me up a post , pretty sure Lowes has doug. fir 4x4's .
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
#24 (permalink) |
After some time at the bandsaw removing everything that didn't quite look like a telecaster I ended up with these...
![]() Then I went to the ROSS to get a little closer to the line. I can't say enough how glad I am that I saved up to get one of these along with the planer. Guitar making is even more fun than it used to be ![]() I wasn't going to use screws for the template until I had a 'duh' moment and remembered that this wasn't really the "top" and would be hidden under the cap. Once that was on I went back to the ROSS as I still had a little more than I wanted left for routing. ![]() I picked up this old craftsman router table with router off of craigslist for $25 and hadn't used it yet. I have a router table that I made a couple of years ago from an old piece of kitchen counter top, but it's sagging quite a bit in the center so I wanted something that would stay level. The price was right so I went for it. I was surprised at how well the router actually worked, looks like it might stay around the shop. ![]() 3 more passes and it looked pretty good...just some raised grain in places to sand down and no real tear out ![]() Chucked in my 1" forstner bit and set the depth at 3/8" using one of the cutoffs from the cap. ![]() doug fir smells really good ![]() on to the other side...should have gotten a before and after weight...kinda curious as to how much all these shavings weigh ![]() Feels pretty light and smells fantastic, now it's on to the f holes. Fingers crossed ![]() This is one of the 2 parts I was a little nervous for...the other is the binding. First drill an access hole for the jigsaw ![]() Then carefully cut out what I can without getting carried away ![]() No screws for this template, I've not had any issues with doublesided tape. I like to put down the blue tape on the work piece first to save some issues that doublesided tape can cause. Between adhesive residue and pulling up of wood fibers I've found this to be the easiest solution. ![]() I put in my 1/4" straight bit and let the shaft be the bearing. moment of truth...close your eyes and pull the trigger...oh wait...keep your eyes open ![]() After the first one I had to take a sneak peak and make sure it worked...looks like the template worked ![]() I do believe this will work ![]() I can't believe how good it looks.
#25 (permalink) | |
I don't know about you, but trying to keep up with everyone's build threads is nearly impossible.
#26 (permalink) |
Excellent job on the f-holes , that's how I do them , 1/4" straight bit shaft as the bearing , first time I did them I was pretty nervous , but I really can't think of an easier cleaner way to do them .
Keeping up with all the challenge threads is quite a task , I try to read and comment as much as I can but it's tough.
#27 (permalink) |
Well today it was on to finishing the chambers with the router. More double sided tape and blue painter's tape
![]() lined up the template and we're ready to roll. I had debated on whether or not to transfer this template over to 3/4" mdf but decided there really was no need...or was there... ![]() Having only a 1/4" template means you have to take off nearly a full 1" with the first pass...I figured since it was an internal route who really cares. If a person takes it slow and goes around a few times taking small bites before pressing in all the way to the template it would be fine...that's a big if. I didn't take small enough bites... ![]() Decided to clamp and glue it back in ![]() Ok..lesson learned ![]() well, lesson learned until the other side...second verse, same as the first... ![]() I never said I was a fast learner...glued and re-routed ![]() Finally after a couple more small bites I had it down to final depth leaving right at about 3/8" ![]() Once I got that done I was ready to glue on the cap. I rounded up all the clamps I could find, smeared on some glue, and lined it up. ![]() It looks like a lot of clamps when I look at the pic, but I wish I had about 5 or 6 more...I hope it glues up well. Maybe I can get the binding started later on tonight. I'll be using .06"x.25" black on this. Still need to pick up paint and clear. I'm hoping to have it ready for paint by the end of the week.
#30 (permalink) |
I took it out of the clamps after an hour or so...probably could have used more glue but I didn't want it to run down the inside edges and be visible from the f holes.
![]() took it to the ROSS to bring the top down some before routing ![]() Once routed I went back to the ROSS and clean it all up ![]() I LOVE MY ROSS ![]() ![]() Thought I'd check the weight now that it looks like a guitar body...4lb 1.4oz...more than I thought it'd be. I'm not sure how much the neck pocket, bridge pup route, jack hole, and rear access route will amount to but probably not another half a pound
#34 (permalink) |
Great work. Coming along nicely. Can't wait to see that body when it's finished.
Other Guy, "But really, how many Telecasters can you have?" Me, "Ummm.... ya, I'm really the wrong guy to ask about that." |
#35 (permalink) | |
Herb, it's making me second guess my plan to paint this one burnt copper. I think it'll look great with paint, but I'm such a sucker for nice grain it's kinda hard for me to cover it all up...especially once I get some shellac on it to seal it.
#38 (permalink) |
I didn't really have any time to do anything tonight so I just checked on the router bit/binding situation. When I got a set of three pattern router bits from Grizzly I wondered why the bottom bearing bit came with an additional smaller bearing...now I know....BINDING
![]() I checked the binding thickness with my calipers...about .051"(and this was supposed to be .060") ![]() Checked the bearing depth...just a little too much ![]() I went ahead and set it up in the router table and did a test on scrap and it actually fits pretty well. There's literally only a few thousandths too much depth there. I figure i'll take that much off with some final finish sanding so maybe tomorrow I can get those channels routed then the neck pocket. I've heard people recommend channels first to avoid issues at the edge of the pocket.
#39 (permalink) |
I've wrapped my bearings with aluminum foil tape to adjust the size slightly and it works really well. In my binding experience it's way way better to have the binding standing proud of the wood. It makes it so much easier to scrape if the binding is slightly tall. You will end up with a perfect edge between binding and paint this way. If the binding is flush with the wood it's a bit harder to get a perfect edge but it can be done. Have you made one of these yet? You'll need it
_______________________________________________ James |
#40 (permalink) | |
My problem now is that I need to get my final sanding done before I route the channel and I hate sanding...
