| 2012 TDPRI Tele Build Challenge 2012 Build Challenge Forum -- check out all the build threads for this year's Challenge. |
#101 (permalink) |
Copper tubing for the pickup wire runs, self shielding. Maybe copper foil forms for the pickup cavities, again self shielding.
Gotta see this one when it comes out of the mold...rock on! |
#102 (permalink) | |
_______________________________________________ James |
#103 (permalink) | |
But seriously, very cool build. |
#104 (permalink) |
Roger
When your ready to pour I think you want to enclose your mold in a wooden frame. The weight of the concrete and the force used to work the concrete will bulge the sides out.
Did I mention I was cheap Proud member of IGPA Ed |
#106 (permalink) |
Just thought I'd serve up some motivation as I'm anxious to see this thing;
http://www.youtube.com/watch?v=hFyQX...ature=youtu.be
Just another squirrel trying to get a nut |
#107 (permalink) | ||||
"The difference is that you're crazy like Nicolai Tesla and I'm more like the guy who sniffs paint and rides his bike down the middle of the road" - Me to Crazydave911 |
#109 (permalink) |
Thank you, Mark. That means quite a bit coming from you.
#110 (permalink) |
Just got some good news. I don't know how many of you ever saw my post last year on screen printing logos, but here's what i was looking at...
I wondered if it was possible to screen print directly on the headstock instead of messing with decals. We have a screenprint shop here at work, so I got my logo sorted out finally and got my screens burned today. I'm pretty excited about it and will do some tests on scrap tonight. I'll post some pics when I get home. Hopefully the cement caster will be the first with my logo
#111 (permalink) |
Good luck with your logo. I've built over 2 doxen guitars to date and have yet to put a logo on even one. I'm shooting for the first on my Challenge build as well.
"Thought that is no longer limited brings experience that is no longer limited" Marianne Wiliamson |
#112 (permalink) |
Geez Roger you're bl**dy mad enough to be an Aussie. Love the concept! Is your mix as light as Hebel Congrete?
For the wiring conduits I'd just use some plastic tubing fitted into the pick-up cavity block etc to wherever it has to go but make it a little oversize in case it compresses with the weight of the 'crete. If you have one of those "Multi Tools" you could easily make an attachment to bolt onto that but the sander should work. Keep up the crazy stuff!! Re the logo why not have an impressed logo on the guitar front? Easy to do just make a thin template and lay it down on the mould face.
" I have this piece of wood that I've cut three times and it's still too short! " |
#113 (permalink) |
As for polishing, around here, all the Home Depots have removed tile (if they had it in the first place) from the floor, and have polished the concrete to a nice reflective sheen. No doubt you could go further with the process on your Seementcaster--nobody's gonna slip and fall while walking on it!
#114 (permalink) |
Here's the logo materials...
The screen. You can kind of see my logo there ![]() Lay it on a piece of scrap ![]() Squeegee some paint across ![]() And VOILA! ![]() My technique needs work. I seemed to press harder as I got to the end, so the lines aren't as crisp. I'm also going to try spraying a light coat of lacquer first as well. I also messed up this screen. I was trying to clean it, but was unsuccessful. I tried mineral spirits, lacquer thinner, and plain water, but it never came clean enough to lay down another print. Luckily they made 2 for me.
#115 (permalink) | ||
#116 (permalink) |
i've been wondering about screen printing the headstock myself. I've put my logo on flat wood surfaces before, but the curve in the tele headstock presents problems for getting the screen flat on the face of the headstock. Are you going to be using a different style of headstock, or have you figured a way around this?
btw, i can't wait to see this thing finished! |
#117 (permalink) |
Got a little more work done on the guitar as well by making my control cavity form.
This form will consist of a piece to form the lip that the cover will rest on, anchors into which I'll be able to screw the attachment screws, and a piece to form the cavity itself. Tempered masonite to form the lip ![]() Got it cut to shape and then drill the holes for the anchors ![]() Use a 3/4" poplar dowel for the anchors. First need to measure. Since the body will be 1 1/2" thick, 1" should be fine for the anchors ![]() ![]() ![]() Next I need to carve some upward-facing barbs so that the anchors will be held tightly in the body. Tool of choice-- the Dremel ![]() ![]() Now I need to attach the control cavity. Using a couple of suggestions from earlier, I'll use a piece of my extruded foam. First I need some dimensions ![]() 90mm x 50mm seems to work well. Next, how deep does the cavity need to be? ![]() Cut out a piece of foam ![]() And attach it to the base with double sided tape ![]() I'll attach my input jack form and wire leads to the to the foam later.
#118 (permalink) | |
#119 (permalink) |
Hi Roger...........Regarding the logo , why not get a rubber stamp made then it's very simple to apply, lasts for years, easy clean up, and you can easily change the colour any time you want, and you only have the initial expense.
#120 (permalink) |
Hey, I may be misunderstanding your idea here but when measuring your depth, shouldn't you be measuring the distance from the bottom of the pot to the threads. Not the other way?
There comes a point in your life when other peoples lives are more interesting than your own. This is a good thing. |
