| 2011 TDPRI Tele Build Challenge Read the "build threads" for the 2011 Build Challenge right here. |
#101 (permalink) | |
#102 (permalink) |
Sorry kids, back to the boring old guitarstuff.
Neck goes int the multi-jig*; ![]() Cheapass router; ![]() Couple passes later; ![]() Freehanded the access hole, TR fits nicely; ![]() Been fighting a strip of maple all morning, got fed up and decided to go with a scrap pice of hardwood skirting board, here it is on the DIY router table; ![]() Not a clue what wood it is; ![]() No table saw or band saw available, so the mitre saw was put to good use; ![]() These TRs have a tendency to rattle (so I'm told) so I need to think up something to stop that. Maybe a little soft chewy candy? ![]() Hacking off a piece; ![]() Kidding ya! That would have made an awful mess one day. I thought this stuff might make for a nice shock absorber. Poor man's bench dogs, bench rug in fact. I cut a strip off, opened the TR put it in between the rod and the... thingy? and presto; ![]() This is the stuff (Dutchies; they sell this at ACTION €1/rug); ![]() Oops... neglected to take a piccie of the skunk stripe in place... Here it is all clamped up; ![]() [* fretslotting jig, doubles as radius-sanding jig, triples as truss rod routing jig, quadruples as thicknessing jig ]
va' sa' du? va' hete' du? |
#103 (permalink) |
Took down the excess of the skunkstripe with the Stanley handplane.
![]() ![]() Using the Hawley neck-pdf's to make little templates for headstock- and heel contour lines I scribbled them on there. ![]() That's it for today. off to 'De Bolle' for beers and either pizza or tapaz after. Tomorrow I start shaping the back profile. SKÅL!
#105 (permalink) |
Something against lefties? HMMMmmm?
"No trees were harmed in the creation of this message, however some electrons were temporarily inconvenienced." My Facebook |
#109 (permalink) |
Olav Nice work you don't seem to have all of the power tools that everyone else has,but your work is fantastic. I've always thought Leftys were more creative than most. You make us leftys proud
#110 (permalink) |
Also I'd like a bit more room to store my crap. Then I get reminded there's people here that build guitars on porches and in sheds that don't have doors. Those are the people I am in awe of. *life as in 'building a guitar', what else kinda life do most of us have?
#111 (permalink) |
Dayum!
Yeah... this;
![]() !!!DON'T DO IT!!! While shaping the back profile I heard a funny papery noise when rasping on the area behind the 1st frets. So, where the TR ends. Rasped right through the skunkstripe... Turns out the no slip mat I thought to use to reduce TR rattle prevented the TR from sinking deep enough into the channel + prevented the skunk stripe from staying in place even when clamped. I've seen lots of guys have disasters on their builds so why should mine be any different? Now I gotta figure out a way to get the skunk stripe out with frigging up the maple it's glued to. Check TR channel depth, relax TR, come up with some other way to prevent rattle and make a new skunk stripe... Bummer. please don't ask for pix...
#112 (permalink) |
Sorry to disappoint lefties on a global scale
What happened here?
![]() You can clearly see there's way too much of that stuff in there. Dunno how I could have just gone ahead and glued the skunk on top of that... ![]() Temporary insanity? I think I'll just start a new neck and leave this to be figured out some other time. Cut your losses and go on.
va' sa' du? va' hete' du? Last edited by Olav; March 14th, 2011 at 06:36 AM. |
#115 (permalink) |
That's right John, moving on. Did bother me yesterday, the new day has me taking this as a learning experience. Just created some 'expensive kindling'
![]() Here we go, making lefties proud again.
#116 (permalink) | |
Dumbass. Over it. Glad I got to it at this stage. I gt me 4 necks worth of blanks at the Bremert last time I was there so I'm not even gonna let it slow me down
#117 (permalink) | ||
Looking forward to the new neck Quote:
#118 (permalink) |
As am I. Next time you see me doing something you think is 'out of the ordinary' or
Back to the order of the day. Thicknessed; ![]() Copied the template on there; ![]() Made some cuts to ease the coping saw's work. You'll notice I didn't cut the perpendicular lines on the 'north side' of the neck, I'll be needing a strip to make the new skunk stripe; ![]() There it is, made a point of cutting closer to the line than I usually do. There's the strip too; ![]() Nice mapley smell in the garage; ![]() Stuck the template on and smacked it on the routertable; ![]() Changed bit and turned over; ![]() Just the one burnmark (vintage correct spot! I deserve a pancake turbo!) and the tiniest little tearout -that'll sand right out when I do the routerseems [edit; that'll even disappear altogether when I thin down the headstock!]; ![]() Scribbled some lines, spaced the TR; ![]() daaaaaaaay-o! day-ay-ay-o! Tomorrow I make a couple $$$ and at night meet with a local guitarist so no sawdust from me till at least wednesday.
va' sa' du? va' hete' du? Last edited by Olav; March 14th, 2011 at 04:43 PM. |
#120 (permalink) | ||
Where do I send the pancake? Quote:
Has it been tallied? |
