Go Back   Telecaster Guitar Forum > The DIY Channel > Tele Home Depot > 2011 TDPRI Tele Build Challenge
2011 TDPRI Tele Build Challenge Read the "build threads" for the 2011 Build Challenge right here.
Closed Thread
Old May 1st, 2011, 04:15 PM   #441 (permalink)
Mojotron's Avatar
That really takes some vision - Wow.... I'm impressed every time I read your thread kwerk.
Mojotron is online now
Old May 1st, 2011, 08:23 PM   #442 (permalink)
kwerk's Avatar
Sorry, I've been a little quiet over the last few days... I have little energy and time available when I'm working to do anything as well as post results. But, another day off today, and negotiated another off tomorrow, so I'll be able to assemble and hopefully get some setup done before recording and posting video tomorrow. On the bright side, I worked out NZ has 17 hours on CST so I have til 5am May 4th to be done, giving me all of tomorrow if I need it.
So anyway! Oh yeah, the build thing...
I got onto decals at last.
Now, some people are not going to like it. After staring at it over and over again, it may be a little OTT, but its in the plan, and as I've said a number of times, if I'm undecided on something, I go back to my original plan.
What I did want was for something different. And it is that!
I started on the back decal and realised half way thru I had forgotten to oil the back of the headstock one more time as I had intended to do. So I had to remove the decal and redo the back as planned. In the process of doing this the oiling rag managed to catch the edge of one of the clock hands and pulled most of the rig out. It's in one piece though, so it will go back in, but its gonna be painted black when it goes back in. The silver is showing up too many of the joins made when rebuilding them, and I don't want to draw too much attention to a part of the build that will be getting replaced as soon as the challenge is over. What i was left with was the tip of one hand still in the hole, so that's what you'll be seeing for this part of the thread!
While the tru-oil was drying on the back, I went back to the front.
Cut the decal ready to go
I'd silvered the dots on the front with silver pen. As part of the design, it was never meant to be overly neat, and fortunately, it wasn't.
The whitening appearance was because I used matt acrylic spray to bond the ink, and the light is catching it. I figured tru-oil would prefer a slightly matt surface to adhere to. I'm not sure why I thought this, but that was the plan, and you know how I am about sticking to the plan!
I then added the next part
And left it to set for a few hours.
I turned over the back, polished the tru-oil (in the process hooking the hands as described earlier) and added the replacement rear decal
Left things a few more hours, then came back to the headstock face to finish things off.
One more decal, and this is why the silver dots didn't need to be perfect. The text itself wanted to have a slightly aged and stressed look, which is why it has the muddy yellow splotches already on the decal. Here it is on the "paper towel"
And finally on the headstock
Went to bed after this. Got up this morning, and hit it with a coat of tru-oil. The whitening has disappeared as hoped, which is good, and the matt surface is slightly glossier than it was, but it will need many more coats of oil post challenge. It'll get one more coat for the time being before being reassembled.
I'm off to figure out the cavity cover and to put strap pins in. Back later with more.
Phil
kwerk is offline
Old May 1st, 2011, 08:30 PM   #443 (permalink)
melomanarock's Avatar
That's an amazing job.. very cool design
melomanarock is offline
Old May 1st, 2011, 08:31 PM   #444 (permalink)
Greg M's Avatar
Where's the cuckoo pop out?
Man, this is a really cool build. I've enjoyed reading along every step of the way. Nice work.
Confucius say man who live in glass house should change clothes in basement.
Greg M is online now
Old May 1st, 2011, 08:36 PM   #445 (permalink)
kwerk's Avatar
Here:
Phil
kwerk is offline
Old May 1st, 2011, 08:39 PM   #446 (permalink)
MORCILLO's Avatar
Great!!
MORCILLO is offline
Old May 1st, 2011, 11:19 PM   #447 (permalink)
kwerk's Avatar
Haha thanks morcillo, can never say no to a bit of DG and the boys
Phil
kwerk is offline
Old May 2nd, 2011, 04:57 AM   #448 (permalink)
kwerk's Avatar
Got onto the cavity cover again. Decided the best approach was going to be to rout from above, and use a larger bit.
Set up the body and cover templates (I used the cover template as a standoff for the pattern bit).
Routed a little at a time til I got to about 4mm, then put a little water in the rout for the last 0.5mm.
After cutting out the cover template I have this:
and, no distortion at all from the other side. I attribute that to the water and the fact the acrylic was clamped directly to the steel router table top.
The cover screwed into place
The little circles are a bit of a bugger, I'll replace that one day
Other covers and bits done
... ain't refraction fun?
Giving the tru-oil another couple of hours to harden up a little more, then the guitar's going together. Just finalising the nutslots now.
We do have another week, right??
Phil
kwerk is offline
Old May 2nd, 2011, 05:05 AM   #449 (permalink)
kwerk's Avatar
Oh yeah, I forgot to mention this before. If you are the sort of person that puts something down somewhere and forgets where you've put it, don't buy protective eyewear like this:
I dunno how many times I haven't been able to find these things!! They are darn near invisible!
Phil
kwerk is offline
Old May 2nd, 2011, 07:48 AM   #450 (permalink)
kwerk's Avatar
Gone quiet in here again
Guitar is together and sounding good. I'm gonna leave it to sit under tension tonight and intonate it in the morning, before making the video and some piccies later in the day. The shims have worked well, and the frets must have gone ok because the action is low and I'm not getting buzzing anywhere. How, I'm not sure, but I ain't gonna question it!!
Nice to have it plug in and make sound at last. The pickups sound good, and it plays nicely. Looking forward to the final day tomorrow.
Got no idea what I'm gonna do after the 3rd May. Might learn how to build a guitar!!
Phil
kwerk is offline
Old May 2nd, 2011, 07:58 AM   #451 (permalink)
kwerk's Avatar
This is not my video, but it's a cool concept! Maybe a variation on this idea for next year's contest
Phil
kwerk is offline
Old May 2nd, 2011, 10:55 AM   #452 (permalink)
deaconque's Avatar
a variation huh? maybe a guitar that plays itself
deaconque is offline
Old May 2nd, 2011, 11:28 AM   #453 (permalink)
whodatpat's Avatar
Tooks great. I love what you did with the headstock. Cant wait to hear it.
E doesn't = MC2, E = Fb
My facebook
whodatpat is offline
Old May 2nd, 2011, 11:48 AM   #454 (permalink)
Originally Posted by deaconque View Post
2 questions-
1. What font did you use for your decal?
2. Where did you get that nut spacing diagram thingy?
curious about those myself.
nice work.
linus™ is offline
Old May 2nd, 2011, 05:53 PM   #455 (permalink)
kwerk's Avatar
The font is Birmingham, and as I said, I dunno where I got the string spacer but I'm grateful to whoever made it. I'm pretty sure I found it here.
Phil
kwerk is offline
Old May 2nd, 2011, 06:11 PM   #456 (permalink)
Nick88's Avatar
here's a copy of the string spacing thing.
I got it from this site, but i can't remember who posted it
Nick88 is offline
Old May 3rd, 2011, 02:53 AM   #457 (permalink)
deaconque's Avatar
Thanks!
Old May 3rd, 2011, 04:08 AM   #458 (permalink)
Michael Terry's Avatar
I can't wait!!
Michael Terry is offline
Old May 3rd, 2011, 06:00 AM   #459 (permalink)
kwerk's Avatar
Originally Posted by Michael Terry View Post
I can't wait!!
Well don't then!
I breathe at last!!
Phil
kwerk is offline
Old May 3rd, 2011, 06:04 AM   #460 (permalink)
Davecam48's Avatar
Jees..... you Kiwis talk funny but you build bloody wonderful guitars.
"Years ago started out with nothing.....still got most of it!"
Davecam48 is online now
Old May 3rd, 2011, 06:09 AM   #461 (permalink)
kwerk's Avatar
Sorry, I didn't understand any of that... what???
(seriously though, transcripts available by PM'ing $2 to "kwerk", TDPRI.com)
Phil
kwerk is offline
Old May 3rd, 2011, 06:12 AM   #462 (permalink)
kwerk's Avatar
And thanks Dave, not all Aussies are bad obviously! (except those that play rugby of course)
Phil
kwerk is offline
Old May 3rd, 2011, 06:26 AM   #463 (permalink)
LeroyBlues's Avatar
Very nice.
Directions? What directions. No one told me there were directions.
LeroyBlues is offline
Old May 3rd, 2011, 06:38 AM   #464 (permalink)
mattyj's Avatar
that's great! i liked the use of 'generic battery amp' to convince the judges that you need a new one ;) I'm sure they don't need convincing though.
mattyj is offline
Old May 3rd, 2011, 06:43 AM   #465 (permalink)
sounds as good as it looks! good luck!!
Old May 3rd, 2011, 06:57 AM   #466 (permalink)
kwerk's Avatar
Well, it's finally done!
Got off to a rocky start and made things rocky for myself several times along the way. Still learning!
It's been nice to see something in my head for so long now materialised, and apart from its many imperfections and shortcomings, by and large it's pretty much as I imagined it would be (but heavier )
It might have been a little ambitious for my second guitar, but if this is learning how to build I think this one was a good teacher. It certainly had lots of curveballs for me. This is my first successful (useable) neck, so I can come away happy with that at least. And I've been able to satisfy some GAS on the way, which is by far the best part.
It'll be nice to have the house back. It's been pretty much overtaken by this project, I gotta get myself a place with somewhere for a shop. And more tools. Can never have enough tools. Next time I build the first thing I'm buying is some fret dressing gear. I think I got useable frets more by good luck than anything else this time round.
So here it is.
Good luck all, what an amazing standard people are setting this year..
TDPRI people are the best and most supportive people on the net, big ups to everyone!!
Phil
kwerk is offline
Old May 3rd, 2011, 06:59 AM   #467 (permalink)
kwerk's Avatar
Haha, actually it's not too bad for a generic "nothing" battery amp..
Phil
kwerk is offline
Old May 3rd, 2011, 07:30 AM   #468 (permalink)
DesmoDog's Avatar
Originally Posted by kwerk View Post
Now that's pretty dang cool right there!
-Craig
http://www.teamyikes.com/
DesmoDog is offline
Old May 3rd, 2011, 07:53 AM   #469 (permalink)
dmarg1045's Avatar
Amazing--great, creative work.
Your problem is, you think you have enough time.
dmarg1045 is offline
Old May 3rd, 2011, 08:19 AM   #470 (permalink)
allen082's Avatar
my hat is off to you, sir.
"so why ya goin to the airport? flyin' somehwere?" -lloyd christmas
allen082 is offline
Old May 3rd, 2011, 08:27 AM   #471 (permalink)
Second guitar?? I figured you must have made dozens!
I really liked the headstock decoration.
What's amazing to me from the video is how woody
the guitar sounds.
Great work -- It's really impressive that you finished
in spite of the earthquake.
flatfive is online now
Old May 3rd, 2011, 08:30 AM   #472 (permalink)
Jazzmeister's Avatar
Wow, congratulations on an amazing build. I'm totally blown away....and I'm not easily impressed. Outstanding design and execution to match! Truly inspirational!!
Jazzmeister is offline
Old May 3rd, 2011, 08:37 AM   #473 (permalink)
kwerk's Avatar
the guitar sounds.
in spite of the earthquate.
Man, you've inspired me so much.. your skills are outstanding, and your guitar is an absolute stunner.
It does sound woody, for sure. The body ended up being more substantial than I thought it was going to be. It sustains til next week, which I guess is a bonus too...
This has definitely kept my mind off earthquakes. We're still getting the odd big one but they seem to be dissipating now. The novelty has worn off, for sure...
Phil
kwerk is offline
Old May 3rd, 2011, 08:45 AM   #474 (permalink)
paesano's Avatar
Many congratulations Kwerk!
Wow. Woke up in the middle of the night. Got up and wandered around. Signed up with TDPRI as a member. Logged in for the first time. Read through your entire build. Was completely stunned and amazed. The sun came up. My wife got up. Linda said your guitar sounded woody and checked out all the details too. Thanks for a very enjoyable middle-of-the-night to all at this forum. I learned a lot and it is a beautiful guitar. !
Very sorry to hear about the rough go of it recently in New Zealand. We were in the "big one" up in San Francisco, and many various other smaller ones in California, and we know the feeling of getting completely shaken up..., so hope all is well.
Ciao, jb
paesano is offline
Old May 3rd, 2011, 08:49 AM   #475 (permalink)
kwerk's Avatar
Ciao, jb
Wow, thanks, man! Nice to have you aboard, you've just joined the friendliest place on the whole interweb!
Phil
kwerk is offline
Old May 3rd, 2011, 08:55 AM   #476 (permalink)
Travst's Avatar
I love it. It just got better and better as you went along. That is a killer guitar. Great job!
I need more practice, not more gear.
John
Travst is offline
Old May 3rd, 2011, 09:04 AM   #477 (permalink)
kwerk's Avatar
Originally Posted by LeroyBlues View Post
Very nice.
Thanks for the nice comments guys. It's been a blast eh?
Phil
kwerk is offline
Old May 3rd, 2011, 09:34 AM   #478 (permalink)
hockeygoon's Avatar
Holy Moly, your 2nd build?
Kwerk this IMO is one of the most innovative looking guitars I've ever seen, while not being excessive--very tasteful. Excellent job, and I am also surprised how 'normal' sounding it is.
hockeygoon is offline
Old May 3rd, 2011, 09:53 AM   #479 (permalink)
rcole_sooner's Avatar
Simply a work of art! It sounds good too. This is a fantastic build.
Earth first. We'll strip mine the other planets later.
rcole_sooner is offline
Old May 3rd, 2011, 10:05 AM   #480 (permalink)
kwerk's Avatar
I realised I didn't make any mention of the knobs and how they are made. I pinched these ones from my first guitar, I've made a few so it won't be a problem to make some more:
http://www.tdpri.com/forum/tele-home...e-edition.html
Phil
kwerk is offline
Closed Thread
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
