| 2010 TDPRI Tele Build Challenge The REALLY OFFICIAL TDPRI Build Challenge -- not some lame imposter |
#62 (permalink) |
Thanks mechaman327.
I just took it out of the clamps. The body weighs a nice 2.4kg (5.3lbs). I don't think there will be much more happening until next weekend, unfortunately. Stay tuned though. Hopefully some goodies turn up in the mail from Stew Mac tomorrow.
The light is going out and everything is tomorrow now |
#63 (permalink) | |
Cheers, Moggl |
#68 (permalink) |
I took the body out of the clamps and it looks good. I will trim it up later in the week. Here are a couple of pics.
#69 (permalink) |
I just did some sums on the build cost and I think it looks like the following list:
Knobs - $7.04 Ferrules - $6.79 Pots - $9.38 Switch - $6.99 Jack - $1.49 Jack plate - $3.19 Orange drop Cap - $2 Realtone Tuners - $29 Fretwire - $7 Pickguard - $21.35 (The blank cost 42.70 and I can get 2 out of it) Neck plate - $4.50 Truss rod - $17 Wilkinson PAF HB Pickups - 2 x $30 (I will need to check this. They are second hand so that could be a reasonable value) Dunlop Strings - $15 Finish - $10 (might be more we will see) Wood - $0 (Thanks to a walk in the bush) Grand total = $200.73 US That leaves me $9.27 to counteract hidden expenses.
#70 (permalink) | |
#71 (permalink) |
After checking again I found I didn't pay that much new. So I will revise my valuation down a bit. $40 US for the pair. I paid $50 Aussie dollars new.
#74 (permalink) |
Drew the f-hole on the body and roughed out the hole. Then attached the template and routed using a 1/4'' bit using the shaft to follow the pattern.
#75 (permalink) |
You may have noticed a headless screw protruding from the body. Accidently stripped the template screw and couldn't get it out of the body. Very annoying.
I pressed on. The f-hole looks quite good. Close up reveals some deliberate hand filing is required.
