| 2009 TDPRI Tele Build Challenge Check here to read the final build threads from the 2009 $100 Tele Challenge |
#61 (permalink) |
Let's see if I have this ...
Trading Hutterites beer for leather as a resourceful way to spiff up your entry in an international $100 Telecaster build challenge? Brilliant! Downright poetic even. All this reminds me of a super Tele player from Canada named Grant Siemens. Plays with Corb Lund and the Hurtin Albertans. Great band -- don't miss them if they come your way. Here's a sample (banjo instead of tele in this case) that even features some Hutterites ... |
#63 (permalink) |
Hey,home at at decent time today
What to do,how about a switch tip and a string tree ![]() Once we have the correct calibers,06 for the tip and a 223 for the tree Cut down the 06 to the correct length. ![]() Make myself a insert out of a scrap of ash
Before throwing it out,make sure it's not 16x13x1.75
#65 (permalink) |
On to the tree
I cut down the 223 brass a bit.Now I need to remove the spent primer A finishing nail works well ![]() Now we have a screw hole!! ![]() Now cut it down and file a couple slots in it,insert screw ![]() My slots are a bit rough.I have about 2000 of these so I will try to clean it up,if not I will just make another one
#67 (permalink) |
Forgive me for going off-topic - but I NEED info. The finish on this jewel looks like Nocaster blonde:
If it is, HOW, HOW, HOW! pray tell did you achieve that color!?!?!? I have been chasing it for a long time with no success.
It was born at the junction of form and function... |
#68 (permalink) | |
#70 (permalink) | |
#71 (permalink) |
Time to try that $1.86 pickguard
When I was in elementary school we use to do leathercraft,but that was some time ago.I even have some tooling stamps here somewhere.Better see if I can hunt them down. Anyway,just not to sure how to cut this guard out.I did a test piece with the router and it actually seemed to work pretty well.As long as I ket it sandwiched between two pieces of wood it cut pretty well with out many fuzzies(not sure if thats the technical term) so I decided to give it a shot I put the leather in between my template and another slightly larger piece of wood so the router bit had wood to cut too. I used the largest flush trim bit I had and made a pass,then switched to a small one for the corner radius of the neck pocket and the bridge cutout ![]() Turned out pretty good.Now where are those tools!!! ![]() The hutterite guy asked if I wanted the leather split.We will have to see if it is too thick.Better be included in the six pack!!!
#72 (permalink) |
Need a nut for this thing
Sure a bone blank is only a couple bucks but........ I have tons of these around here ![]() Slice one up and head to the sander ![]() Man this stuff stinks when you sand it ![]() Gettin close,time to move to the sandpaper
#73 (permalink) |
Well it fits in the slot,after I removed some goop out of it
![]() Cut it down closer.Think we will leave it there for now ![]() Hmmm,there is a lot of horn left What can I make with these??
#77 (permalink) |
Uh, nice rack, Marty! Sorry, it had to be said.
According to my wife, "the true beauty of free will is that you can continue to be stubborn" |
#79 (permalink) |
One of the best Canadian bands ever. They were way ahead of their time. Sort of country meets Danzig sound.
Torn Down Units brand Rock n' Roll |
