Originally Posted by callaway
It's pretty simple really. Want more flexible effects (both routing and tweakable options) than the Pods? Want a 30-second looper? Want something incredibly easy to use (I can't tell you how simple it is to use compared to anything else)? Don't need amp/cab/mic models? The M13 is the answer.
I thought I used to love my Vetta with full floorboard (had for 6 years). Then I got a 15 W tube amp and an X3 Live... that was just okay. The X3 is great if you use it for DI and amp/cab models, etc., but it just doesn't have the mojo running through a tube amp (even if you run straight into the poweramp of the tube amp). So I ditched the X3 Live when the M13 finally came out, and I couldn't be happier.
Okay, I'm convinced. I'm going for it! I have a refund coming on a Vox AC15 that could not get delivered. When that check gets here, I'm pulling the trigger on the M13. Thanks! I'll keep you posted.
