Old July 18th, 2009, 03:12 AM   #15 (permalink)
DanofTucson
DanofTucson's Avatar
Mesquite 'o Varius neck troubles
As I said, I had to repair the old Kay upright bass.
The problem was the original factory neck joint separating after some forty odd years of abuse.
The light color you see in the joint lines is bare wood showing, because the tapered sliding dove tail joint is separating.
The verticle line through the curve of the heel to neck transition is an old repair that occurred before I owned the bass, and still holds with no problem.
DanofTucson is offline   Reply With Quote
