Old July 8th, 2009, 02:34 PM   #20 (permalink)
dankomal
Originally Posted by jwells393 View Post
dankomal.......... I'll ask you once again. What's that all about? How is putting glue/gunk under the 7th fret marker suppose stop a rattle? The 7th fret marker on a vintage neck covers only one thing ........... the hole drilled to accept the fret marker.
Did he remove the marker and drill a hole down to the truss rod? As you can see, there's a lot of wood between the 7th fret marker and the truss rod on a vintage style neck.
Compare that to a neck with the Bi-Flex truss rod that has a screw under the 7th fret marker.
Sounds to me like your guy doesn't know the difference. If you want it fixed, send it to mellecaster.
yes, he drilled down to the truss rod. my mistake in describing the job.
thanks for showing the pics though, it give me more of an idea how thr rod works.
mal.
dankomal is offline   Reply With Quote
