Originally Posted by Sl8e
That's a little beast!
I use GK stuff now. I have a BL600 Head, two BLX 210 CABS, it's the little rig that could.
I generally use Peavey amps. MARK IV head, 215 cabs.
Peavey 115 combo with 210 cab.
Centurion head with 10's as well.
Digitech effects and compressors. And a killer octave under pedal. I'll never tell who makes these.
For the money, you can't go wrong with G-K! My 210 combo has the same head/power as your BL600 (just re-packaged into the combo).
I'm not after mega stage volume and with the direct out, you don't have to be. With a 5 string/Low B, this set up sounds very sweet! If I were going for a Head/Cab set up, it would probably be the same as I have; A BL600, the 2x10 BLX and the 1x15 BLX. To me, it's just the best "all around" set up for bass.
