Old July 6th, 2009, 04:36 PM   #107 (permalink)
eagleeye
I got my AXE back from the tech without any work done. He seems to never be in a hurry to do my work and has SCRATCHED the crap out of my acoustic using a drill to replace my strings and then had the nerve to say it was done at the factory which was more than I could swallow! He did spend over an hour buffing out the scratches but I have not been back since until my girlfriend took my Tele in. I wanted her to go to the other shop but she opted for Bernies instead! I can now do this myself and follow Eddies revised diagram for my reverse control plate. I will take my time and follow the diagram and "GET HER DONE". Here I go again......................I love the smell of hot solder!
Originally Posted by Deaf Eddie View Post
Well, that's just lovely.
The FIRST thing I see is IT APPEARS that you have your pots and pup selector switch reversed - pots towards the neck, selector towards the bridge. Is that the case? If you said something about that, I must have missed it or misunderstood you.
If that's how you want the controls laid out, what it means is that you have the 4-way rotated 180 degrees wrong - so when the lever points bridge-way, you the get the neck pup, and vice-verse.
And also, you have the tone pot BETWEEN the volume and the 4-way. That doesn't really change anything, but it sure makes your layout NOT match any of the drawings that I created for you. No wonder you're having novice issues. Bad input = bad output.
If you like that layout, and have enough leads, you should rotate JUST the 4-way so that the common lug with the bridge pup's hot is closest to the tone pot.
If you DON'T have enough leads, do not despair, here's a drawing with the corrected 4-way layout and the volume/tone layout to match the picture you posted of your control plate:
Although NONE of this should affect the issue of the neck being on all the time, you never can tell... Flip the switch OR rewire it as shown, and see if that resolves anything.
eagleeye is offline   Reply With Quote
