Originally Posted by Jaxson612
How does it do clean country?
In my opinion, this pickup does not do country music tones well at all. This pickup is definitely flat out rock. For country, I would use my Duncan Alnico II tele bridge pickup or something similar. This BG1400 removes some of the bright twang and bounce that I associate with country music. I think if you used this and split the coil with a push/pull pot, it would get you somewhat of a country tone, but more full and more punch, but less twang.
Originally Posted by caliban335
What value did you use for the tone and volume control pots? Did you stick with the standard Esquier wiring or use the "cocked wah" option in place of the "bassy" tone?
Thanks.
I used audio taper 250K pots for vol & tone. The tone pot is the push pull. There's nothing standard or traditional about my wiring. I did my own wiring schematic based on a bunch of things I've observed from other guitars. I use a 4-way switch that utilizes two "cocked wah" settings. Here's my schematic:
