Digitech Digidelay... hands down
The Digigdelay is hands down the best first pedal for several reasons... you have 7 different options in one pedal. Most importantly though is the #5 position is called modulate or modulated which is a pitch bending chorus. I had 2 in my train for a while because they are that versatile. You can use the #1 position add time and keep the feed back low and you a good reverb effect. Most bang for you buck... and the kicker is you can find these all day long for 40-50 used and they are built like a tank. Experimenting with a single pedal like this causes appreciation for versatility. When I had 2 I would use them together and set the time shorter on the first and slightly longer on the second... causing a very cool galloping effect... much like a U2 setting. Also great for a huge full never ending note or chord that just goes on and on...
Hope this helps and good luck... and all the best
