When padding light cuts, you can get away with several applications in a day. With any other method, be wary. I may be preaching to the choir here. In any case, it's not a bad idea to give it a day or so to harden up when you've put on several light coats. Especially if you're thinking of sanding. I've learned that patience with shellac is just as important as patience with lacquer.
Tim Little - Virginia
"Often wrong, but never in doubt."
