Old July 4th, 2009, 05:27 PM   #12 (permalink)
dankomal
Originally Posted by lamprey999 View Post
Don't know if it will help...and don't let yourself be photographed while doing it...
You might try using a small enough Phillips head screwdriver, as a stethoscope- handle to the ear! (I've seen mechnics use extension bars, screwdrivers, and such to isolate mystery noises in running engines. This is safer- no moving parts!)
Put the point carefully, but solidly on the headstock. generate the noise, and then move it around to different spots. You should get it louder as you near the source. If not it will make for interesting pics at your next party!
I tried the philips screwdriver but couldn't locate exactly where the rattle is coming from.
my hunch is its coming from one or more of the kluson deluxe tuners but I have no idea which one?
how could I find out? are they easy to open up and check if they are loose inside?
thanks,
mal...
dankomal is offline   Reply With Quote
