Old July 4th, 2009, 01:21 PM   #13 (permalink)
yegbert
yegbert's Avatar
Boris, can you explain your theory that the springs keep the sound from being clean?
My goal is to see if I can get more harmonics like I seem to get with 3 steel saddles, from 6 steel saddles. I think my tone is too clean with the setup already. I'm not sure yet if this is helping, I need to give it some more time.
I don't know whether the force would be enough to eliminate the springs.
I'm using a plate that's at least as thick as, and seems to be stiffer than, any FENDER PAT PEND plate I've tried. It doesn't appear to have become bent when I tightened these screws down, but I've been conservative in tightening them down so far. I don't remember this plate's exact thickness measurements and I can't measure the bottom part now with it installed. I have its' measurements in a post somewhere here. But I agree it makes sense to start with a good stiff plate.
