Well, there is a learning curve involved here, and you not only tried one of the more difficult mods (Fender 4-way scheme) to wrap your head around, but complicated it by adding a push/pull or two.
I bet if you had just tried to do it in steps, (first, replace pickups; then add p/p to coil-shunt; then try the 4-way mod) you might have made it all work - it's just too tough to troubleshoot when there is so much going on at once.
YMMV - I been wrong before...
