Tube socket on a Fender Super Reverb
So, I have a late 60s/early 70s Fender Super Reverb that I've had for about 5 years now (the tube chart with the serial is rubbed off and torn just where the numbers are -- and I haven't opened the chassis to look at caps and transformers...my old tech told me that he was pretty sure it was a 68, and I know it's at least a 68 because it's silverface with push/pull master).
Anyway, I have an issue with my #2 power tube (farthest from input in the circuit): sometimes when I turn on the amp, the filaments of that tube don't fire up, or other times, when I am playing for a bit, that tube will kick off (I can hear a noticeable difference both in volume and in tone -- becomes very flubby) -- when I check the power tube, sure enough, the filaments aren't glowing, and it's cold. I know the tube itself is fine.
Is this most likely a bad tube socket, or do I have to expand my options to a possible bad place in the circuit connected to this output tube? As simple as a loose solder joint?
Thanks for any help!
dave b
