Old July 2nd, 2009, 10:57 AM   #261 (permalink)
Puresoundguitar
Puresoundguitar's Avatar
Machinin parameters
Hi Ed,
Thanks for this great thread, it has been a pleasure to read through!
Can you enlighten me on a couple of things?
How do you achieve that awesome finish after machining the back of the neck?
I'll be doing a neck soon, CNC'ed, and i'm aiming at 0.001in scallop height, with a 1/2 Ball-nose.
Will be machining at around 50ipm, 12000rpm.
Can you give me your input? Are these reasonable values?
Ok, second question:
When cutting your fret slots, can you give me your parameters? I mean, depth of cut, feed, spindle speed...
In my case i'm aiming at .008 - .010 in terms of depth of cut...
Any help will be gratly appreciated.
In the meantime, this body was machined with a .005in scallop. Not too bad, but i'm aiming for a better finish.
Thanks in advance!
Puresoundguitar is offline   Reply With Quote
