Old July 2nd, 2009, 10:40 AM   #5 (permalink)
dankomal
Originally Posted by surfoverb View Post
what do you mean by rattle? Why would the G rattle? If you're getting like a harmonic note then its probably the nut. Try tying a piece of rubber band to the G between the nut and the tuner.
the rattle is like zinging aftersound, though it does also sound like something is loose at the headstock end, even though i've checked and can't find the problem.
is tying the rubber band on the g string to check the problem is with the nut??
cheers,
mal.
dankomal is offline   Reply With Quote
