I will do that. I do have the neck green to common on the switch and the bare to the volume pot ground. The green from the neck pup is on the bottom left and the black from the bridge is on the top right according to the diagram. The red/white of the neck is on the middle left lug of the push pull pot with the black on the front left lug of the push pull. The neck green is to the bottom left common with bare to the back of the volume pot. I will do the meter test now and get back to you! THANKS for the HELP!
