Old June 30th, 2009, 05:30 PM   #51 (permalink)
davebelcher98
davebelcher98's Avatar
Originally Posted by Oldschoolwax View Post
WOW, that's crazy low action, I run closer to 1mm at the 8th fret! standard "starting" action for Teles is usually 1.6mm at the 17th fret, I'm guessing you're way under. You my need to shim the neck a bit or shim up the saddles ( neck should be way easier... )
Like that old "relic" Bridge you got! hehehe! gotta take your knobs and control plate for a weekend at the beach in NC!
They are sort of snake like aren't they?! On the relic -- yeah, I was thinking the same myself...some sand, salt water, and some sun might do the trick...
davebelcher98 is offline   Reply With Quote
