Old June 30th, 2009, 03:53 PM   #69 (permalink)
eagleeye
the screw neck is weak on #4 but the other is sounding and the bridge both sides are strong in #4 position. When the Push pull is pulled #4 the neck is dead but the bridge is active. #3 they all are strong. doesn't make much difference if the push pull is in either position. #2 the neck is strong on both but weak when pulled. #1 they are all strong both neck and bridge but the neck is the strongest. When pulled the screw in the neck is louder than the other in #1 position. When pushed down they all are strong both bridge and neck in #1 position.
eagleeye is offline   Reply With Quote
