cmm71, mojo2001 has good suggestions and observations there. I have had some good Crest era Gibsons from '63 and early '64. The double-angled cabs that came later are not as good....as mojo said....bright.
RE: JEnsens and 'vintage correct'. For Gibsons, JEnsens were usually silver in color and not blue as the Fender JEnsens were or as the modern JEnsen speakers are.
Good luck with it. IT is a hand-wired amp and can be modded. Take advantage of MOjo's offer. You can learn more from a challenging amp than you can from one that is 'good to go'.
