Old June 29th, 2009, 06:16 PM   #63 (permalink)
Deaf Eddie
Deaf Eddie's Avatar
You mean, you're wiring this scheme up and you don't know what it will give you?
Yikes! How will you know if it works???
Basically, it's just the Fender 4-way scheme: bridge/both parallel/neck/both series.
The p/p will coil-shunt the neck pup, which you will hear in throws 2-4, when the neck pup is playing.
The drawing is the drawing is the drawing - just follow it. The bare leads from the pickup bundles go to ground at the most convenient place, usually the back of the pots.
YMMV - I been wrong before...
Deaf Eddie is offline   Reply With Quote
