Old June 29th, 2009, 05:51 PM   #62 (permalink)
eagleeye
I will give it a try. I took everything apart and will resolder it all back up. This time I can do a better job with wires and I have a better soldering iron which gets hotter faster! I think the output jack is probably the culprit as I changed it to a switchcraft and probably wired it wrong. I have it all apart now so I will try again. Thanx Deaf Eddie once again! You are the MAN! Can I ask what I get with wiring it this way? I mean the switch wiring to pup action! And do I still wire the green and bare for the bridge to the back of the tone pot and the neck pup bare only to the back of the volume pot with the green to the common on the switch?
eagleeye is offline   Reply With Quote
