Old June 29th, 2009, 04:22 PM   #11 (permalink)
wetland10
Originally Posted by teletin View Post
AFAIK the use of the neckbucker by Keef is debatable. It appears that there are no photos proofing he ever used the neck pup (the switch is always on the bridgepup). The fact it is there does not mean he is using it (there are many tele players that use only the neck or bridge pup while having both on the guitar).
I've read a lot about that. To summarize, he does/did use the neck HB on his Custom, that's been documented.
As far as it goes with "Micawber," what I have read is that he had the HB installed. I would assume that you would install it to use it rather than to look at it. I also read that he might have older or custom wiring with a blender pot and blends in the HB.
Just some theories.
Wayne
My band, original rock and blues:
http://www.loneshark.net
wetland10 is offline   Reply With Quote
