Old June 29th, 2009, 01:10 PM   #59 (permalink)
eagleeye
I am getting ground noise with my setup. It gets louder when I touch any metal on the guitar. I checked my wiring and it is all correct. Can you check the schematic or do you have an idea as to what is causing the problem? My tele is BUZZING. I will try and isolate now. Other than that it seems to have good sound. The push pull pot works for the neck humbucker and tone works also. I am pretty sure it is a minor issue but have no clue where to start? I had the wire grounding the bridge plate and it is grounded to the bottom of the plate when screwed down. I am LOST now! HELP! Deaf Eddie, Can you hear the BUZZ? SOunds like a bumble bee and gets louder when I touch metal on my axe! Any clue?
eagleeye is offline   Reply With Quote
