Old June 27th, 2009, 07:31 PM   #82 (permalink)
oigun
Hi Tuur,You dont have to fill pine because it has no open pores.. just sand it flat with a block u[ to 320grit or so then wet the surface,let it dry and do the final sanding. Then stain and lacquer. When you want to do a solid (dekkende) color you can use 2k filler(polyesterplamuur) to smooth it out.
oigun is offline   Reply With Quote
