Old June 27th, 2009, 06:27 PM   #57 (permalink)
eagleeye
Deaf Eddie; I drilled the control plate and now can install the new 500k pots. I will install one push pull volume pot and one tone pot. Both will be 500k now. How should I wire the setup with the 4 way switch and use the 500k push pull as volume and 500k as tone? SORRY TO BE SUCH A PAIN IN THE TELE! I just want to make sure it is done correctly and of course will have the BEST sounds! I just can't talk myself into routing for the other push pull as the cavity is too shallow in the place it is mounted! Any advice will be greatly appreciated form anyone whom has knowledge! Can you draw up one last diagram for this idot?
eagleeye is offline   Reply With Quote
