Old June 25th, 2009, 01:42 AM   #46 (permalink)
eagleeye
Oh I guess I was way off on the the C's. It's great to know IYHO brands of caps make no difference so I will stick to the orange drops and go with .022uf for starters. I will tape a few on a piece of cardboard and clip them in to find the best one before I solder it in. Seems to be a great way to do it. I see Seymour Duncan recommends 250k pots for the Lil 59er but I have the 500k audio taper push pulls. Do you know what the difference will be? Maybe I should have gone with 250k? I'll get them if you think I should? It's great to hear the Lil 59 will coil-shunt nicely so hopefully it will be as good in the bridge. The sh1 59 four conductor hopefully will match up with the Lil 59er's sound both single and humbucker positions? Honestly I am guessing they will and used the tone chart on SD to decide. I also have a Phat cat which I was going to use first for the neck before getting the s1 59 four conductor so if I don't like the S1 59 I will switch to the Phat cat. Would you know if it will be an easy swap between the two or will I have to go back to college? Does the phat cat coil-shunt? It is I believe a single coil in a humbucker casing so I did not think it could be? Any idea what I could do with the Phat cat in the neck position with the four way and push pull's along with the Lil 59er in the bridge?
eagleeye is offline   Reply With Quote
