Originally Posted by edwardjeffrey
I have a 3/4 scale bass of unknown origin.The neck is very narrow(2" at the heel)and I can't seem to find any bridges with a narrow string spacing.Anybody now of a bridge with a 2" spacing?
The
Schaller 2000 will adjust anywhere from 45mm (about 1 13/16") to 54mm string spacing. This is not the more widely known Schaller Roller Bridge. It uses a 5-hole pattern that's the same as a standard Fender bass bridge. Just be aware that it has a very low profile, you may have to shim beneath it. You should be able to order it through any store that deals with Allparts.
