I would add this:
Maintaining your equipment.
Starting with YOU. You must be in shape to perform any physical [i]or[i] mental activity. Especially, if you want to do it at a high level.
Do you keep an extremely rigid schedule of Sleep? Do you eat well? I'm no fanatic here. But, Steve Vai, Eric Johnson, Jeff Beck (I think JB anyways) are all Vegetarians. So, whether you are or not isn't the point. Just that it points out there are more aspects to reaching your peak, than sweep picking arpeggios, etc.
Do you use Technique that maximizes your facility, while minimizing any potential damage?
Do you play too loud? Could bite you later on. See: Pete Townsend.
Do you hold, pick and fret in a good posture? I have Tennis Elbow, Carpel Tunnel Syndrome and Tendonitis in both arms. DRAG! Because of improper practice for extended periods of time.
Etc., etc., etc. There's a lot to it.
I am definately not wanting to be discouraging. Not in any way! But, you gotta acknowledge these things.
Start slow, and build up a routine that maximizes everything about you. Physically, Mentally, Morally and Creatively.
I'll stop now. Blah, blah, blah! :)
Just some stuff to chew on. Dedication is often under-appreciated nowadays. And I commend anyone who has it.
One of my favorite quotes, is from a famous guy (Thomas Edison):
"Opportunity is missed by most people, because it's dressed in overalls and looks like work."
Hope this helps to fire you up!
"Rock On, Rock Soldier!" (Another great quote, from Ace Frehley)
