Old June 20th, 2009, 03:17 PM   #2 (permalink)
WYfish
Mr. N,
You won't mess anything up. The truss rod in a Taylor works the same as other guitars. The nice thing, and advantage to the bolt-on neck, is that if the truss rod adjustment doesn't change things enough for you, a tech can do a neck re-set really easily. If you go to the taylor website, they have some info on adjusting the truss rod. that'll help you if you have any questions. Also, not sure if you're already doing it, but storing the guitar in its case when not in use will help with the humidity. Good luck.
WYfish is offline   Reply With Quote
