Old June 13th, 2009, 01:50 PM   #10 (permalink)
emiller45
emiller45's Avatar
Originally Posted by pbenn View Post
Everything might be in the wrong key for you, too. Not that you're going to get everyone else to change, but you may discover you're not as bad a singer as you thought.
But to check it out, next chance you get, try one song in private, capoed at the fifth fret, sung in your easy baritone (but up a fourth).
Then you can experiment by moving the capo up and up until you reach the original key, I guess.
This concern for being in a key appropriate to your voice is the first thing that occurred to me. You can determine your range - the highest and lowest notes that you can comfortably sing. You may need to change some keys to accommodate your range and/or choose songs that don't exceed your range.
Don't believe everything you think
emiller45 is offline   Reply With Quote
