Old June 12th, 2009, 02:11 PM   #23 (permalink)
lonewolf
you got it! It is a great big tortoise shell colored triangle pick. I don't think anyone uses them to play with that I have ever met, but they make a great neck shim. Get the medium one, it seems to be the correct thickness for most neck shimming situations. re-read my earlier posts, and be sure to get it in the back of the neck pocket with the widest base of the triangle closest to the bridge. It usually allows the neck mounting screws to go right beside the pick, not through it. If you have to, you can trim out some small notches for the neck screws with a pair of scissors, but in most cases you don't have to do that. Good luck.
Gene Warner
repairman
lonewolf is offline   Reply With Quote
