Sonar Producer is great but the learning curve is steep - as it's with all "semi-"/professional recording software. Best to choose one and stick with it, in the end they all pretty much do the same thing (well, considering). And if you are only using it at home, you'll probably only need 10% of all its functions.
I think the point is that you shouldn't be afraid to take it on. It's not hard at all to get up and running, recording audio and MIDI. The greater mysteries/functionalities of the program will unfold as you work with it.
