Old June 3rd, 2009, 07:02 PM   #12 (permalink)
DarnWeight
Thanks again, cc.
Grounding the pot with a piece of wire as you suggested at least proved it was actually working. I had one last idea though...and luckily it worked. It seems this switch is very picky about which side of the common terminal you use. Rewiring as in the attached image below, and everything now seems to work as it should. Now I just need to sort out the godawful grounding buzz...I have a feeling this may well be linked to the constant (and messy...I'm a bit of a novice with an iron) "solder-unsolder-resolder" I've been resorting to try and get this circuit to work!
DarnWeight is offline   Reply With Quote
