The options are the same, but there are possible issues with a P90. If it's a three-conductor P90, no issues. If it has a vintage style braided shield lead, big issues.
The braided shield in those pickups is not only the ground conductor, it's the coil's negative conductor. Any series or phase options would put that braided shield - and all the metal parts of the pickup, including baseplate, magnet, mounting screws - on the hot side of the circuit. Since that pup has a PLASTIC cover, that at least doesn't add to the problem.
A common band-aide is to run the length of the lead through some heat shrink tubing to insulate it from touching anything in the control cavity. However, with all that metal on the wrong side of the circuit, this mod may be susceptible to unwanted noise and hum.
YMMV - I been wrong before...
