Old May 22nd, 2009, 05:40 PM   #6 (permalink)
Freight Twang
Freight Twang's Avatar
Originally Posted by BrianF View Post
Either way..drill a hole or cut a slot works just fine. All you want to make sure is that the B string does not contact the bridge metal in any way. There's really not much to it other than that. I routinely just cut a slot with a Dremel tool with grinding wheel disc cutter bit. Make sure you wear eye protection etc.
Yep, what Brian said!
Freight Twang is offline   Reply With Quote
