Old May 20th, 2009, 01:19 PM   #20 (permalink)
Deaf Eddie
Deaf Eddie's Avatar
You can wire the 4-way to give you your bridge pup in coil-shunt, although many players find that coil-shunting the single coil-sized humbuckers just gives them a drop in gain, rather than a new and different timbre as it does with full-sized humbuckers. So, your bridge pup would be working as a single-coil pickup, but it wouldn't SOUND like a Tele single-coil bridge pickup - just a weaker version of its humbucker tone. It IS easy to wire it up that way, if I haven't scared you out of it.
The stock modern Tele middle throw is the pups played in parallel. This is a sweet, "clucky" tone.
The 4-way mod (wired as Fender intended) adds a combos playing the pups in series, which is a fatter and slightly louder tone, reminiscent of a humbucker.
YMMV - I been wrong before...
Deaf Eddie is offline   Reply With Quote
