Old May 7th, 2009, 11:57 PM   #56 (permalink)
KajuJam
Hello All,
This is my home-made version. One pedal is missing due to I am getting ready to trade it tomorrow.
I used a 34X16 ATA case and build the board from half inch aluminum angle for light weight. It has a power inlet I just plug a plain extension cord to. I have a BBE Supa Charger underneath powering the pedals.
The jacks on the left are;
FX loop send
FX loop return
Footswitch
Output (to amp)
I use a home-made snake to connect board to amp.
I use Corex2 gold tip cables. They are crystal clear. Best cable I have found and inexpensive too. The downfall is the huge collars makes them hard to position pedals too close. Solution is I run most cables underneath.
Oh!, Almost forgot.....the switch on the top right powers three blue LED light strips (three bulbs each) under the board. LOL, I know, a little extreme but I have electricity under it....why not??? There is no limit when you make your own.......
KajuJam is offline   Reply With Quote
