Regarding the two 4-way switch diagrams, I assume they'll work fine for two humbuckers as well (that is, a humbucker in both the neck and bridge). Given the way the two diagrams are wired, I assume the inner coils would be made active. Is that correct?
Are you asking if BOTH pups can be coil-shunt by the 4-way? Then, yes.
Are the drawings here correct for that? NO. They would have to be a bit different.
It's not quite clear to me what you want to achieve. Tell us what you want and we'll see what we can do for you...
