If you're willing to shell out for the peterson then I would urge you to check out the turbo tuner. Its MUCH smaller, more accurate (+/- .02 CENTS), programmable, true bypass and costs $130. The tracking is at least as good as the strobostomp.
IMO there's the turbo tuner and then the rest.
If you don't need the accuracy of the TT for intonating your guitars then the PitchBlack is absolutely a step up from the TU-2. It's smaller, cheaper, tracks better (not sure whats going on with the 12 string/mandolin post?), better display and true bypass.
