Old April 20th, 2009, 10:48 PM   #10 (permalink)
telesavant
telesavant's Avatar
Originally Posted by yegbert View Post
telesavant,
Brilliant idea!
I was thinking about doing something like that to force the saddles together, but I hadn't figured out a good way how. What thread size set screws did you use?
The threadsize is 10-32....smaller will work, but the larger the size of the set screw....the more leeway with saddle adjustability up and down and back and forth while still making contact. Remember....adjust and intonate BEFORE you do the mod then mark where to drill and tap. I just cut these to length from a longer screw, and slotted with a .025 dremel wheel....instant set screw.
telesavant is offline   Reply With Quote
