Old April 16th, 2009, 08:41 PM   #4 (permalink)
mrSlush50
the same scale will work for both major and minor. it just depends on where you start. try a sliding scale like this in E:
e----------------------------12-14s16-16s14-12---------------------------
B----------------------12-14-------------------14-12---------------------
G--------------9-11s13-------------------------------13s11-9-------------
D---------9-11-----------------------------------------------11-9--------
A--7-9s11---------------------------------------------------------11s9-7-
E-------------------------------------------------------------------------
Notice the note I started on, 7th fret 5th string is an E, my root (tonic) note. Notice also that every fifth (penta) note played is an E. Hence, PENTA-TONIC. (Sorry if I'm oversimplifying or telling you things you already know.) So for a lead part for a song in key of E, find the spot you want to play in then grab a section of this scale that starts and (more importantly) ends on the root note and play it in tempo. That can function as a lead line on its own. You can then start adding variation and variety from there.
EDIT: Ok something about what I just wrote doesn't seems quite right to me. Can someone with more music theory knowledge tell me if all that is technically correct? Sax: it should work just the same, even if I haven't explained it correctly.
mrSlush50 is offline   Reply With Quote
